Old 08-13-2010, 04:39 PM   #12 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Where is this block heater supposed to be installed? You mentioned a plugged hole. If these holes are the soft plug holes you do not want to install a block heater in both of them as they are there to prevent your block from cracking if the coolant does freeze in the block.
The Following User Says Thank You to ConnClark For This Useful Post:
Piwoslaw (08-14-2010)
