Old 08-15-2010, 12:51 PM   #49 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
The issue with the fog lights is that there are flat surfaces around the fog light cup, But the flat surface curves around with the bumper. Its hard to explain in a literary sense. In the forward facing plane, there is a flat surface. But if you look down on the car, bird's eye view, the flat curves around the bumper.
Its almost like I need to bow a piece of plastic. BUT need to remember this fact, the Subaru Fog light bulb is a 9006. The same 55w bulb used in dozens of cars as the actual head lamp. Those babies throw some heat, and trapping the air inside may result in the bumper melting or the aeromod melting. So the material needs to be heat resistant. Not to mention being that low to the ground, it will need to withstand a pelting of gravel, rocks, sticks, etc.
I may need to purchase a toaster oven and build a mini thermal bower. hahaha
