Originally Posted by pgmomni
When I bought the 15" pizza pans they were too small, needed the 16" pans to fit my 15" steel wheels correctly.
I had the same problem. The 13" pizza pans I bought on eBay were about an inch smaller in diameter than the 13" wheels on my car. My pizza-baking needs were already covered, so I'll make it work... I'm not just throwing out that $20!
For those of you thinking about ordering pans, grab a tape measure and check your wheels first, as
the rim size is actually listed as the diameter of the tire's bead. Fairly common sense but if two of us can miss it, others will too.
