Old 08-16-2010, 04:21 AM   #30 (permalink)
jackbauer
jackbauer's Avatar
Not sure i understand why a smaller drive sprocket would cause the chain to hit the arm. A larger one yes. Anyway I have an option on a 50t driven sprocket so i could use a 14t drive to get almost the same 3.58:1 ratio which is only one tooth less than stock:
Honda CBR600 FM-FT 1991-1996 50T Talon Rear Sprocket on eBay (end time 16-Aug-10 12:09:26 BST)
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
