Old 08-16-2010, 10:55 AM   #39 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by Clev View Post
Ouch. Seems a little high, doesn't it? If you decide to make this a kit, you'd probably be able to find a shop that would do them in quantity for half that.
The cost is high because the steel that is being used is really tough and a carbide cutter had to be used instead of a high speed steel cutter, with that a single cutter can only make two shafts before it wears out, it also takes 3 hours to make each shaft on a CNC machine due to the splines, if the shaft was longer and there was more room to over run the cutter then it could be done differently and quicker.
