I wonder how it compares to the previous gen's 1.6L.
It's easy to make an Insight idle, in which case it burns 0.11gph. I should repeat that trial with the headlights on and see if it's 0.13gph like I predict. Hmm, could it really be 0.09gph with zero 12V load instead of the 200W base load?
Originally Posted by bwilson4web
(Sorry, I don't understand Ecomodder tables.)
That's fine, I understand text tables quite clearly. If you want a monospaced font, that's [ code ] [ /code ]
If you must have a table, I recommend
Free BBCode Table Generator Tool
