Originally Posted by RobertSmalls
I've assembled a MIMA controller
I just finished installing the DIY MIMA as well...Still trying to figure out all the functions. Where/how did you mount your joystick, and also how did you mount the display?
I also noticed moisture under the carpet, and I'm not sure that can be helped either.
Ouch, I would figure out where it was coming in if I were you. That can only get worse...
