Old 08-17-2010, 01:50 PM   #55 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I have used a heat gun on the inside of curves when using coroplast. It takes practice but keeps it's shape and makes the part a lot stiffer. Don't overheat the outside.
This picture shows the curved areas that were bent gently using heat on the inside.
The Following User Says Thank You to Varn For This Useful Post:
MetroMPG (08-18-2010)
