Old 08-17-2010, 03:11 PM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If you are going to argue that something works because it doesn't fallow the same rules as the rest of science then you need to cite sources and not just say that someday 1+1 might equal 5...
The only way that I could see any device putting out more mechanical force then the electrical energy that is put in to it is if it also pulls energy out of the air or something as well, if it did this then instead of a motor getting warm as it ran because of the friction inside, it would instead get cold as it absorbed energy from around it, if it simply created energy... then you would be creating energy.
