Old 08-17-2010, 08:16 PM   #5 (permalink)
user removed
24,000 miles rotated once.
This car was totalled and I had it repaired. The alignement has never been checked or adjusted.
I go around corners fast enough to discourage most tailgaters.
Original 8-93 front brake pads have 50% left.
No problem in wet weather, and I might drop the pressure in snow.
Contact patch size is reduced with higher pressures which places more weight per square inch on each square inch of contact patch.
If that is misinformation then show us we are wrong.
The 3 grooves in the attached photo measure .230 average with a variation within .005 inch!
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
Christ (08-27-2010), mcrews (08-21-2010)
