Old 08-18-2010, 06:57 AM   #20 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Try to keep your rpm's low, under 2200 rpm, more or less. Adjust the pedal based on the amount of power you need to keep moving up the hill, but don't floor it all the way. If your rpm goes down to the point where you are not getting power, downshift. Try to crest the hill at the lowest speed possible (as traffic allows). This takes good timing and judgment to know when to throttle off and try to coast over the top, creeping along at the peak of the hill, then rollercoastering your way down.
Nissan Versa Aeromods
