Old 04-10-2008, 11:04 PM   #3 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
yep, sounds like a loose heat shield.
You should be able to idle the car while parked and initiate the noise by s-l-o-w-l-y revving the engine up through about 3000rpm.
At some point in there the vibrations from your engine will reach the resonant frequency of your loose heat shield and promptly set forth a cacophony of rattling. Then you can easily find it, and fix it.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
