Paul , would it be possible to have a brake signal input to the controller from the brake light switch? If throttle is non zero or motor current greater than 10amps and brake is appled kill power.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
