Thread: Worth a shot..
Old 04-11-2008, 12:01 AM   #17 (permalink)
FX2.3
Saving Those Greenbacks
FX2.3's Avatar
Snowy - '02 Ford Ranger XL
90 day: 23.29 mpg (US)
Originally Posted by RH77 View Post
Make sure you're not giving it full-throttle to get going -- if forces the ECU into Open-Loop (which would subtract the efforts)
Good work on the technique though -- keep it up
RH77
I cut it off at 2k when starting off and if needed allow it to get up 2.5k or 3k depending on traffic but quickly get back under 2k..
I am thinking of making a spoiler type thingy, basicly clear plastic sheet screwed into the plastic bedliner (possibly hindged so no one messes with it when parked); leaned against the tailgate and cut so it gets the 10-12 degree from the cab.. and get some black abs plastic around the skidplate to cover the gaps between the bumper, tires, and skidplate..
Blue outline = plastic..
Do you think it will help?
I am going to to try to leave much of the truck alone until I can afford new rims/tires and lower it..
[/URL]
