Originally Posted by EdKiefer
Ok, So your able to set a offset voltage to lambda to trick it from normal 14.7 .
If my memory is right you said your using haltech stand alone ECU ?
The haltech works off a cross over voltage, 500mv right now. The wide band has an output that mimics narrowband cross over voltage, I have set the wide band to cross over (500mv ) at 15.6:1. The control unit of the wide band will produce a voltage signal mimicking a narrow band but tuned to the a/f ratio you desire. Hook it up to the ecu and your golden
