Old 08-20-2010, 07:30 AM   #573 (permalink)
electromike
It is so nice to see interest being generated in this project again. I found that most peoples interested in developing for the project ends once they have their obduino running well for their purpose. As is what happened to me, and why my updates stopped.
One test that could be done to see if it is your car that is causing the re-init problem would be to unplug your device from the car while it is actively reading results from the engine. Then plug the device back in and see if it will reconnect. If it reconnects just fine, it would be the code, if it doesn't, it might actually be your code.
If it does reconnect just fine, I will be willing to look at your code as well, I put a lot of effort into revising the ISO init protocols to the proper standards and timeing and am curious about this problem. matthews(dot)mike@g m ail. co m
