Old 08-20-2010, 02:25 PM   #186 (permalink)
GeneralAnarchy
Its not discharge in the cell, it is discharge from the balancer. The last charger was probably 2 weeks ago. I'm not sure about the connector, it just corroded.
That's good to know. It would be good to see a picture of the bad plug. I searched for corrosion and found related info on RJ45 ethernet jacks www.keithl.com: RJ45 page and a guy says "if you stuff any connector with silicone grease (not glue!), it will even work under sea water."
For application to the Enginer PHEV phone jack, if they have this grease at Fleet Farm or somewhere it seems like a cheap investment
