Old 08-22-2010, 07:38 PM   #26 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
yes, size does matter, at least thats what those ads say...
Originally Posted by beer View Post
Choosing the right size off tyres for better milage, is always a comprimise.
You have to look at which roads you drive the most.
If you drive alot on highways, then you better of with narrow, but large tyres.
The frontal area is less, less rpm's, less rolling resistance, but much heavier.
If you drive a lot in a city, you're better of with small, but a bit wider tyres.
Less unsprung weight, less rotating mass, but more rpm's.
Even better is when you use a bit widther rim then normal, becouse your tyres walls get
stretched and get stiffer, so you can take corners at greater speed.
And always look at the rolling resistance and weight of the tyre, becouse these differ between manufacturers
Michelin is the only tyre producer that i know of that doesn't only look at rolling recistance.
They released a few new tyres 10" sizes and a relative narrow 195/55r21 tyre.
Becouse they to confirm that it always a compremise between the two.
In my experience, which is 95% hwy driving at interstate speeds, 65-75 mph, larger diameter tires even if they are wider/heavier results in better mpg. The "taller" gearing results in lower RPM's which almost always improves hwy mpg.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
