Old 08-23-2010, 02:10 AM   #89 (permalink)
jamesqf
Originally Posted by Varn View Post
Most of my driving neighbors drive fairly high vehicles, I can only assume that most who were killed in Missouri were driving compact cars.
Instead of just assuming, why not check to see if this is in fact the case?
You might also factor in deer-caused accidents, where the driver crashes in the process of trying to avoid the deer. Obviously, a smaller, more maneuverable car will give you better odds of safely avoiding (or failing to avoid) a deer. Certainly I've managed to avoid a number in the Insight. (Including one that seemed determined to be hit: I saw him in the road and swerved left, he jumped left. I turned back to the right, he turned around and got in front of me, Back to the left, and the sucker jumped again. Finally came to a stop (I was of course braking the whole time) inches from him - and he snorts and WALKS off the road.) In a couple of instances, I might well have rolled an SUV or pickup doing the same maneuvers.
The Following User Says Thank You to jamesqf For This Useful Post:
tumnasgt (08-23-2010)
