My motor is going to be off set to the right side by about 7 inches, this gives me enough room on the left side for another battery next to the motor.
Your splines are impressive for being cut free hand, I was going to try to make splines on the mill with the corner of and end cutter but it was not the correct angle, it might have worked for a while but I want mine to be as exact as possible.
I also wanted something that, if it all works out correctly I can make more for anyone who wants one, after all most of the work is in figuring out how to do it the 1st time.
