I will make an airdam/grille block whenever I get the time. I have cut some pipe to extend the bumper about a foot, then take a piece of 4 mil plastic from over the grille to the bottom of the airdam frame.
I wouldn't be suprised if I had to cut holes into the sheet to let air flow through to the radiator. I think I will cut two holes out the same size/shape as the holes in the grille. The sheet will also cover the "bucket" headlights and wrap around the truck a little.
I'll tighten the whole thing up with whatever heat gun/source I can jimmy rig up
