I received it last night and hooked it up after my late dinner it seems to work well but I have not owned a Scangauge to compare it to. It will take some time to get the location just right where I want it and finish selecting the readings to display. The windshield mount works well so far the mast is a bit stiff so I might velcro it some where later to keep things off the window. The unit is light weight and smaller than a GPS unit.
I wish that there were a few more gauges for my car mostly EGR.
Biggest complaint from first use is changing pages when driving is a bit slow or seems to not want to change at first. That could just be me not knowing if I should hold the button in or tap it.
On the way home tonight I may try doing an EOC to see how it reacts, although it might not like the fact that my car drops the MPH to 0 on restart till I put it in drive and tap the gas.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
