Old 08-25-2010, 10:09 AM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by 320touring View Post
Sorry- the car is a 2.0 PETROL turbo
Well then that's easy: For good fuel economy you want a warm air intake. That means:
  • The air intake should be moved into the engine bay, behind the radiator is best,
  • You can block your intercooler, or
  • Take it off, thereby freeing up the intake flow.
In any case the upper grille can be blocked, while lower should be used to regulate the coolant temperature.
