Old 08-25-2010, 10:50 AM   #1 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
New record distance!
I just beat my distance record! Thanks to an excessively hot summer, among other things. It took 7 weeks of commuting, 10 miles at a time. I started with the tank topped off until gas was sitting in the filler. I ran it down until it sputtered and died. A gas can (2.000 gal) in the back got me to the station for the rest of the fill.
1133 miles
13.751 gallons
82.4 mpg
Mods:
Grille block - smooth upper, 3/4 lower to leave a little airflow
Tire pressure - high
Mobil1 5w20 oil
Scangauge
Battery trickle charger. Too much EOC runs the battery down. 0.74 kwh for the tank.
A highly adjusted nut behind the wheel.
Techniques:
P&G EOC
conserving momentum
light timing
route selection
low speeds
low rpm shifting
parking at the uphill end of the lot, facing downhill for a rolling start (I enter at the top, so I just stop there)
NO AC
The Following 4 Users Say Thank You to PaleMelanesian For This Useful Post:
2003protege (09-17-2010), endurance (10-05-2010), j12piprius (03-09-2011), vtec-e (10-04-2010)
