Originally Posted by Piwoslaw
Well then that's easy: For good fuel economy you want a warm air intake. That means: - The air intake should be moved into the engine bay, behind the radiator is best,
- You can block your intercooler, or
- Take it off, thereby freeing up the intake flow.
In any case the upper grille can be blocked, while lower should be used to regulate the coolant temperature.
thanks for that suggestion!i'd been considering the wai, but dont particulaly want to lose the punch of the turbo-its ideal for low rpm high load pulses..
I'm hoping to have some time to look at the car this weekend- so i can see where to mount rear wheel covers and to see about a grill block.
What sort of gains in mpg would you expect from a grill block?
