You could make the slots smaller or larger and adjust the amount of movement by using a simple mechanical arm that would be configured like so.
_
..\_
The top line would be the actuator the \ would have a pivot point in the center and the bottom line would be connected to the sliding portion. By adjusting the pivot point and length of the \ you could change the amount of movement for opening the grill. (Ignore the .. it was used for spacing since I can't create an image now at work.)
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
