Old 08-25-2010, 04:19 PM   #6 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by 320touring View Post
What sort of gains in mpg would you expect from a grill block?
About 2%, according to the wiki: Grill block partial or full.
thanks for that suggestion!i'd been considering the wai, but dont particulaly want to lose the punch of the turbo-its ideal for low rpm high load pulses.
If you still want cool air for performance every now and then, then maybe a dual air intake? One warm, one cold, and you choose which is open with a switch. Fuel efficiency: WAI with blocked IC. Performance: CAI plus open IC block. Also helps when the engine starts to overheat.
