Well, to help the mirror issue, you could use a camera setup. By eliminating your mirrors and installing cameras you would significantly reduce drag (I have a bus, and the mirrors are almost as much frontal area as most auto front windows). The advice of cleaning up the front end is good advice as well.
Google Image Result for http://roadracingoverstock.com/ProductImages/Trucks%20002.jpg
With a diesel, turbo pressure increases efficiency. Dont lug the engine, but try being more patient on the road instead(i.e. sometimes we pass for no good reason).
As for the trailer, I dont know how much time you spend hauling a load, or not hauling, but it may be worth it to close up the wake of the truck. I am thinking of a wedge like device that goes from height A by the truck and decreases to deck height, or height B over some distance, C. Making it easily collapsible and storable would be the only thing that would be difficult. Good luck!
