If I am ever in Texas I am going to stalk you and learn all your secretes.
Originally Posted by PaleMelanesian
I'll likely not be pushing it this far again any time soon. My mpg drops at the end of a tank. It gets tricky to restart the car, due to poor fuel pressure, so I use more engine-on coasting instead of off. The tank was at its highest of 84.8 mpg 100 miles earlier. If I can't beat the distance, it's better for me to fill sooner and use less fuel. Also, less possibility of stressing the dry fuel pump.
I have a "hesitation" on restart when down below 2 gallons left. I have to bumpstart and let the engine stabilize a bit longer before I can let the clutch out and pulse again. If I bumpstart then let the clutch out right away the engine will die for an instant.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
