Old 08-26-2010, 04:33 PM   #215 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Christ View Post
Bonus points!
Even more bonus points if you can make the feed line dump using only the pressure generated by heating the container!
That is easy just make the feed container a pressure vessel and use gravity feed. As long as the container's water is level is below the manifold you can have a feed back line to it. see the attached picture. The pressure of the vessel will never exceed the pressure of my manifold. As long as it will hold at 70 psi I'll be fine.
I'd imagine that might work alright. However, if you inject too much steam you'll reduce your efficiency though. I have no idea where that limit might be though.
I imaging that point would be more than I would ever run because I would have to top of the feed tank too often.
The Following User Says Thank You to ConnClark For This Useful Post:
Christ (08-26-2010)
