Old 08-27-2010, 09:26 AM   #11 (permalink)
Drive Stick
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
320, if your engine bay is anything like that on my 1998 saab 900 turbo with the 2.0t .. you should be able to quite simply install a filter in place of the stock air filter box, and it will suck in HOT air. In fact the shiny turbo heat shield you see there, I had made to lower intake temps since the stock one was missing. If I remove it, intake temps rise like crazy.
Fabricating under-body flat panels will be a great addition. Lowering the vehicle helps a lot, though most people on here aren't interested in that sort of modification it seems. Lower you are to the ground, less air travels under the vehicle / simple / cheap.
Blocking the intercooler would be a no good idea unless you fabricate an under-car airdam which directs airflow over the intercooler - the engine will run too hot under boost and high loads without sufficient air passing through it. (especially with a hot air intake installed.)
Fashion some wheel well covers for a cheap removable way to increase gas mileage.
