The goal is to be able to FAS (Force Auto Stop, ie stop the engine) while in neutral without touching the key, ie without having to switch off/on the ECU.
The engine doesn't consume fuel when you remove your right foot only when you are in engine brake, so not in neutral.
With engine break your car is slowing down very fast compared to neutral, noticeably when your car is aeromodded and with tires pumped up to max side wall.
Have fun,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
