euromodder -
Originally Posted by euromodder
Not maybe.
Engine-on coasting is what got me above 47mpg (or below 5L/100km) .
I was using DFCO and braking as little as possible before I started coasting, so the combination of both is inferior to engine-on coasting.
Yes, but I think DFCO has a strategic purpose for us. Going down a steep grade while coasting is not a great idea from a brake-overheating POV. However, if I can get engine-braking + DFCO on the downhill, I can avoid using my brakes and risking dangerous speeds.
If I had a fuel-injector cutoff switch, I could use it for manual DFCO.
CarloSW2
