lost you re-attachment
3d,if I had to guess what happened,I'd say the the Protege originally had the typical notch-back downwash which would have allowed the sepatated flow from the roof to re-attach at the back of the trunklid.
The Kamm-back is causing an 'overshoot' condition,directing the air out into 'space' where it cannot re-attach,and consequently increasing the wake size and lowering the base-pressure.Both bad.
I like what you did with the plex.I would either extend it further back,or extend the back of the trunklid back and up at a 30-degree angle ( no steeper! ) with a spoiler to give the air a place for re-attachment.
Some cardboard and duct tape should make a showing on your coastdown.
