Old 08-28-2010, 08:29 PM   #3 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Good luck but I doubt if you can fabricate a door as light and stiff as the original steel door.particularly if you are looking for smooth.
I see you used spray foam to fill in. Companies like Aircraft spruce and Wicks sell a two part foam that works very well and is much stiffer and cheaper than the spray foam at the box store.
Your door would be best left a base for a more aero structure. Just my opinion.
Noah Webster, 1787
