euromodder, I read once on this forum about aero "go extreme and enjoy" (I don't remember the exact wording and can't find the sentence). I'm not extreme yet but I already enjoy the new ride my car is offering me. 1 week ago I also pumped up my tires to 4.0bar (58psi) while I had them at max side wall = 3.5bar (51psi) since one year. The change in the ride is as much incredible as when I went from 3.0 to 3.5bar (44-51psi). Also I hope my FAS kill switch will permit me to push my results farther.
I blocked the upper grill in winter. This was so effective that I could hear wind noise in the wipers as soon as 70km/h (43mph). Last time I changed my wipers I bought some "low profile". I drove 550km on highway (110-130km/h 68-81mph) at temps as high as 15°C (59°F) without heat problem, but at my daily commute speeds (closer to 70km/h than to 90km/h 43-56mph) I had heat problem very quickly over 10°C (50°F).
There is also a gap between the bumper and the headlights. I already taped it when I was trying an invisible tape, but this one was becoming hard and cracking, but overall removing it was letting lot of residues. The best way I found to remove these residues was to let them under the sun to dry, then to rub with a dry cloth but some yellow color may stay. I decided to not close these gaps again while I have better things to do on the car to improve it.
I'm using "power tape". It's multi-layered with a strong middle layer containing intersecting threads. The packaging indicates resisting to temps from -5°C to 70°C (23-158°F) and to water.
Have fun,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
