Here is my idea from my intro page, I moved it here to get more specific..
I am thinking of making a spoiler type thingy, basicly clear plastic sheet screwed into the plastic bedliner (possibly hindged so no one messes with it when parked); leaned against the tailgate and cut so it gets the 10-12 degree from the cab.. and get some black abs plastic around the skidplate to cover the gaps between the bumper, tires, and skidplate..
Blue outline = plastic..
Do you think it will help?
I am going to to try to leave much of the truck alone until I can afford new rims/tires and lower it..
I would like to know where I can obtain the plastic sheets needed, about what thickness I would need for my application, and if it would have any noticeable affect. The bed needs to retain usage so a cap or full cover is not ideal.
Thanks you,
-James
Specs on the truck;
2002 Ford Ranger XL, 2.3L, Automatic, 2wd, 4.10 Open Diff, 3" Front Spindle Lift, 2" Rear Blocks, 31x10.5r15 BFG All-Terrians, 15x8 American Racing Ventura Alloys, K&N 77 Series Intake System, Catback Magnaflow Dual Exhaust, SCT Tuned,,
