Old 08-29-2010, 01:36 PM   #8 (permalink)
Arragonis
The PRC.
Originally Posted by Arturasz View Post
Thanks for info Arragonis. Mine engine code is AFN, which I don't see in your given list. It is not PD one, it is VP. I also don't see ALH which You say that is OBD2.
What does the plug look like ? If it looks similar to the OBDII one I would 'risk it' if it was me. If it doesn't work at all then punt it on ebay - they seem to hold value reasonably well or you can use it on another car.
Originally Posted by dcb View Post
even if it "works" it won't give accurate mpg on a diesel.
EDIT: assuming it works like we think it does, based on the publicly viewable behavior.
Although I doubted this (and started a thread about it somewhere) I got one anyway for other gauges like temp, MAP etc. On the first tank (i.e. pre-calibration) it was way under the on board measurement for MPG in all instances - setup for the under-endowed US gallon I assume
Now after 1 calibration tank mine is more or less matching the on-board to within 10% average MPG. It is usually pessimistic in comparison but then again the built in one usually paints an overly rosy picture - and of course has no facility to apply calibration corrections which the SG2 does at each fill-up.
One big advantage of the SG2 is having AVG and instant MPG always visible. Simple technique is to learn how to keep instant over average in different situations - hills, motorways, city driving etc. It paid for itself on 3 tanks in my car - Diesel is that expensive in the UK
Mine is the PD ASZ engine (130), I set it to Diesel 1 fuel type.
