Thread: Cold Safe Room
Old 08-30-2010, 10:37 AM   #6 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Originally Posted by skyl4rk View Post
In any case, both for thermal efficiency and material cost efficiency, a dome shaped structure is required for extreme insulated structures.
I think this is one instance where it sounds good in theory, but . . .
It will be a LOT easier and probably cheaper to build a structure in a rectangle or cube shape that will use readily available insulating materials and add more insulation than to make a dome. You could make a superinsulated wall with 2x6 framing or offset 2x4s, put fiberglass inside the wall, then add foam on both sides. Last time I looked at geodesic domes they had to be specifically engineered and used special attachment plates at each joint.
Also, the usable volume inside a rectangle will probably be much greater than in a dome. I'm not really fond of bumping my head on the wall every time I move around a room.
Let's look at the example you presented in your first post and compare a dome to a cube structure. For a dome with an 8 foot ceiling (in the center), the radius of the dome would be 8 feet.
Area of sphere = 4PiR*R
Area of dome = 4PiR*R/2 = 4 x 3.14159 x 8 x 8 / 2 = 402 ft sq.
Area of floor = PiR*R = 3.14159 x 8 x 8 = 201 sq ft.
Add area of floor to area of dome: 201 + 402 = 603 sq ft of area for total structure.
603/384 = 1.57 times as much surface area for the dome.
So a dome you could "live in" would be worse, from an energy standpoint, than a cube. Granted, you get more floor area with the dome, but you'd be hunching over much of the time to keep from bumping your head on the ceiling/wall.
If you set the surface areas equal on both the dome and cube, the heat loss would be the same, so there would be no advantage thermally to either one. But the ceiling height will be lower for the dome, perhaps too low to make living in it acceptable. And if you want to put a door in the dome, you will have to flatten one of the walls and have the dome at least as tall as the height of the door, so the amount you can lower the ceiling will be limited. The dome will be harder to build, but it would offer more floor area to store survival equipment or to put thermal mass.
