The hubcaps are store bought, the reason for the offset is that the radiator is offset, unseen inside is a aluminium plate on the right side directing the air through the radiator. The alternate explination is that I am "asteticaly challenged" and therefore have no apreciation of symmitry. Some of my artistic friends would atest to this... One feature that can not be seen on the "mustache" upper grill blocker is that the bottom edge projects out about an inch so some air still gets into the radiator from the upper grill. Daox thanks for the pics transfer it would have taken me hours to get that done. The under body is the mark 1 and still a bit rude and crude, the mark 2 may be installed this winter, with a Kammback over the rear window. my antenna is still in place, for now, can anyone tell me where I can get one of those 1 inch high plastic antena seen on some bmw's.
