Originally Posted by CapriRacer
You would think that but the data suggests that there are other things that may have more impact. I've tried to catalog them here:
Barry's Tire Tech
Are you sure about the testing methodology you mentioned here?
When tires are measured for RR, one of the test conditions is the load - which would be larger for larger tires.
Do You have a link to a description of the testing methodology? I've never heard of upping the test weight/force for larger tires.
