Old 08-31-2010, 07:12 AM   #119 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by roflwaffle View Post
Are you sure about the testing methodology you mentioned here?....
Absolutely! You can even see it if you compare the 2 graphs. It's obvious there is something that changes the RRF to RRC - and that something is the test load.
..........Do You have a link to a description of the testing methodology? I've never heard of upping the test weight/force for larger tires.
Google "SAE Rolling Resistance Testing" Lots of references there to RR methodology.
