Old 08-31-2010, 10:25 AM   #2 (permalink)
Daox
It would be comparable to 3rd or 4th gear for most cars. Honestly, its much easier to just connect the motor to the transmission input shaft. Otherwise, you literally have to hack apart the transmission, make your own or customize the output shaft so you have a gear to connect to the differential gear... It would be tons of work.
The Following User Says Thank You to Daox For This Useful Post:
WaxyChicken (08-31-2010)
