Old 09-01-2010, 04:50 AM   #4 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Except on the hinge side, it is easy to add insulation all around the door seal. Fuzzy mating surfaces may be optimum, but hard to clean. Hard-coated foam parts can be progressively glued in place to give virtually zero air space where the insulation parts. You can also use door weatherstripping material, and a mechanical door latch. Along the hinge edge, you can extend the hinges, or use flexible insulation.
