Old 09-01-2010, 12:00 PM   #81 (permalink)
Daox
Originally Posted by bs0u0155 View Post
I also thought about adding in control from the brake lights. i.e. if the temp is above a set minimum, then the grill opens up whenever the brakes are applied, adding alight aero braking and "free" cooling.
Interesting idea. However, in winter this would not be ideal. You could do it if you still referenced the coolant temp and made sure it was above the thermostat open temperature.
