How about putting your fridge on a timer. Recalling all of my hurricane training, I remember that a fridge can remain without power for about three days without spoiling the food inside with quick access to what you need.
I would suggest setting up a timer that would shut off power to the fridge after a certain time, like after dinner and kick on again before breakfast or later depending on when you first use it in the morning.
It may just save you a couple cycles a day or more depending on your fridge.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
