Ben - Your battery box is where the stock fuel tank used to be, right? Doesn't your 'metro have a spare wheel well, accessed from inside the boot?
If yes, Then cut it out and make another battery box there. I assume you don't carry a spare wheel with you for weight reasons? Even if you can only fit another 2 in there, that would get you from 72v up to 96v..
