Old 09-02-2010, 04:29 AM   #20 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by SvdM View Post
The only way I think [for now] a cover over an existing alloy wheel might work is if you tap the back end of the nuts that hold the wheel in place [with an M6 hole or so], but there are so many different alloy wheel designs that you'd battle to make this work for all...
I wouldn't build a business plan on the hopes that people will start drilling their alloy wheels or wheelnuts.
Relatively few people go about modifying their cars.
Even fewer modify their cars for better fuel consumption.
I do think Vekke's plan can work if the parts are easy to fit ; if fitting them is reversible without damage; if they're effective at reducing fuel consumption (that is: the proven mods on the ecomodder list); and if they're cheap enough not to scare people away from the initial investment.
