Old 09-03-2010, 03:36 AM   #4 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by dcb View Post
is the OBC off by a consistent percentage? the sg readings may be related to the dieselness of your vehicle.
The OBC is usually off by 0.1 to 0.3 L/100km, most often reading low.
At least the Scangauge can be calibrated based on actual consumption
Also make sure your refueling technique (same pump, same depth/angle of insertion, same number of clicks, etc) is consistent.
Inserting the nozzle is always done the same way.
Since I started using the Scangauge, I've always used the same fuel station, but not always the same pump. There's no incline.
Inserting the fuel nozzle is always done the same way.
