It would be pretty easy and cheap to use zote foam to fill in the gaps if you thought it necessary. I am surprised that no one here has worked with it.
Here is my biggest creation with it.
It is made from 1/2" thick foam with a minimal plastic/carbon/balsa frame. The chassis is a Catrike, Pocket.
Originally Posted by euromodder
Honda had an experimental trailer for their Insight 1 that continued the ideal aero shape further, leading to reduced aero drag.
They used flush but flexible panels to bridge the gap between towing vehicle and trailer.
– Noah Webster, 1787
